My 55 Bel Air has a steering column that I presume is original to the car. It appears the car originally was a column shift, but that is not the case now. However, that collar is on the column. I don't know if that matters, but I thought I'd mention it.
Here's my problem. When I tighten the 3 screws that attach my signal housing to the column, via that 3 pronged do-hickey, it doesn't prevent the turn signal housing from slipping in one direction, ie counter clockwise. when I hit the signal indicator down, this rotates the whole assembly, and it can come loose. The problem doesn't exist in the clockwise direction, because the design of the column has stops in that direction. Is there any other way to secure this, to keep it from slipping? Thanks. John
