Thermostat recommendation for a Blueprint 383
10K views 5 replies 5 participants last post by  kbuhagiar
#1 ·
Hello folks,
Today I discovered that my Blueprint 383 engine doesn't have a thermostat.
The car has always run exceedingly well, always around 185-190, and I had no indication that the thermostat was missing.
My inclination is to put one in, as I was taught that you should always run one on a street car. Seems that a 180 degree unit should be just right for a carbureted non-emissions-control engine. What say you?
And finally, any good reason to leave it out?
Thanks! :flag6:
Discussion starter · #6 · (Edited)
if IT RUNS AS YOU SAY IT DOES, THAN WHY MESS WITH IT AND CAUSE A POTENTIAL LEAK AREA. I HAVE RUN WITHOUT A THERMOSDT FOR YEARS WITH NO ISSUE IN MY 406 ENGINE
If It's not broken , Don't break it ! Leave it alone . :flag6:
While I appreciate the notion to leave well enough alone, the thermostat housing has already been removed and will need to be replaced.
