I am frustrated by the stock throttle pedal linkage hooked up to my 2x4 carb setup. There is too much resistance with 2 carbs and 2 return springs, and the physics arent really good, so that a short travel of the gas pedal leads to a larger opening of the carbs Hard to modulate the throttle. either too much or too little throttle.
anyway, after failing at my own custom pedal setup, I am willing to try the lokar set up. but I do not know if I can remove the old throttle linkage with the engine in. i can't really see the 2 bolts behind the engine
DOES ANYONE KNOW IF IT IS POSSIBLE TO REMOVE OLD THROTTLE PEDAL LINKAGE AND INSTALL LOKAR ONE WITH THE ENGINE IN THE CAR?
