When I turn the nut on the upper ball joint the bolt turns along with the bolt..Is the top of the bolt screwed into the balljoint?
I've been there and frustrating, I've tried several things, but the one I had good luck with was to use a drag link removal tool, (the one with the U on the end of a shaft) and drive that between the upper part of the spindle just below the ball joint, which provides enough force to keep the ball joint from rotating when you turn the Nut to loosen it. Worked for me, best of luck, BDR...When I turn the nut on the upper ball joint the bolt turns along with the bolt..Is the top of the bolt screwed into the balljoint?
Thanx for the answer BD.I was worried that it would pop off before I was ready & take my head off.I've been there and frustrating, I've tried several things, but the one I had good luck with was to use a drag link removal tool, (the one with the U on the end of a shaft) and drive that between the upper part of the spindle just below the ball joint, which provides enough force to keep the ball joint from rotating when you turn the Nut to loosen it. Worked for me, best of luck, BDR...![]()
Hey, glad to hear you got it broke loose, I didn't realize you had enough thread to grab with the vice grips, but that was definitely the best way since you did. :congrats:..I had about a 1/4" of the bolt sticking through the bottom of the nut so I put some vice grips on the end of the bolt and tightened up the nut to get the tapered bolt to grab.Then loosened the nut and all went well from there...
The ones I removed from my 57 that originally had a 6 cyl were 16.5"I would search on the topic of springs before installing. The new short spring is going to make your car very low in the front. The stock spring is about 16.5" and your new spring has very tight coil spacing too.
Was the car originally a 6 cylinder?Does anyone have any idea why the PO would have used such long springs? I put my 300 pounds on the front frame horns and the front end didnt go down even an inch unless I jumped up & down..
Yes they are 1 1/2" lowering springs..I like the old school "rake".The tires are 14s so I'm sure that I wont have a problem.If I do have a problem,I'll just go w/smaller tires.The whole front end including the ball joints is new.Be sure the ball joints are good before installing the new springs. This is not a job you want to do twice. Are these new springs lowering springs? I ask because sometimes there is a wheel clearance problem if they are.:anim_25:
