I just bought a new set on Com Camp valve springs, and the seat pressure is advertised as 112 pounds @ 1.900, but measures 80 lbs. Is there a chance that the box was marked wrong, or that the wrong springs were packaged in the wrong box? Thanks
did you measure the installed height?? sounds like the height is too big.I just bought a new set on Com Camp valve springs, and the seat pressure is advertised as 112 pounds @ 1.900, but measures 80 lbs. Is there a chance that the box was marked wrong, or that the wrong springs were packaged in the wrong box? Thanks
Make sure your measuring error is not greater than the thinnest shim.:tuI am checking every valve. Most are the same, but others require more shims. I bought these springs because of the advertised pressure, but had a big surprise when I checked them. Seems like they would be close, but no go.
Thanks. I'll let you guys know how things work out.Make sure your measuring error is not greater than the thinnest shim.:tu
Don
