Vented gas cap for a 57
6.5K views 6 replies 5 participants last post by  Chevyragtop57
#1 ·
Do you run a vented gas cap on your 57's. Having some issues with fuel delivery and my mechanic suggested the tank needed to be vented. Running a stock cap, tank, sending unit, and Carter mechanical pump. If you are running a vented cap where did you purchase? Thanks
#2 ·
A vented cap is required on a 57. 55 and 56's have a notch in the filler pipe so a vented cap is not required but won't hurt to have one. Danchuk shows how their gas cap is vented to block fuel from squirting out under hard acceleration. http://www.danchuk.com/ItemForm.aspx?Item=140
You can test your cap by turning it upside down and filling it with a liquid to see if it runs out. As shown, the hole should not be straight through.
