1 - 20 of 31 Posts
mars57
My 350 engine on my 57 Belair needs the correct alternator bracket. The one it has now was fabricated many years ago and it does not look good. Does anybody know which alternator bracket to use on this ram horn exhaust manifold #3749965? and where can I get one. Thanks .
I used 2 passenger side manifolds and used this
Bolts to front of the head . Best picture I could get
Discussion starter · #3 ·
Thanks Shadetree 55, I do have an extra RH side manifold #3747038 laying around somewhere. I would still need the correct alternator bracket for either of the two manifolds. Where can I find these brackets. I don't even know what they look like for this application.
GEEEEEEEEEZ, this is just toooooooooooooo easy..
Simply use your basic 63-68 Chevy alternator bracket. There was both a left and right side alternator used on SB Chevy engines.
These are pure, bolt-on, factory Chevy parts for the alternator on my 51 Chevy with a 389SB. Too simple.
Discussion starter · #8 ·
The bracket on you setup doesn’t look like the one I have. Yours seem to bolt higher on the exhaust boss allowing more adjustment. Mine only adjusts toward the fender wall.
@mars57 I would follow @DZAUTO and @56ls408 's advice...The brackets they have recommended will look correct for your application
All you have to do is put 1963 impala alternator bracket in the search bar on ebay & it brings up several (But) here are 3 item numbers that will work there are more.Another search 1965 Corvette will bring up several but because it says Corvette they think the bracket is gold.
124385724062
194814371317
264891108018
OK everyone. Sorry I took long to reply to you all. With your help and a little searching I finally ordered the lower alternator bracket. I got it from Speedway and I told the Tech that if it did not work I would return it.
Got a link to the Speedway bracket. so we can check it out?
D&R ClassicM00181 lower alternator bracket for small block chevy, #92611842, from speedway motors
What is the distance between the center line of the bracket bolt holes on your manifold?
1 - 20 of 31 Posts
