Looking for a column cable adapter kit that goes from original column to powerglide trans. I see the kits that go to the TH trans but do not know if they work for PG. Thanks
Please show us what kit you are looking at....Who is the manufacturer?Looking for a column cable adapter kit that goes from original column to powerglide trans. I see the kits that go to the TH trans but do not know if they work for PG. Thanks
If your referring to the Lokar cable shift, the power glide doesn't have a pan like the TH, so you would have to fabricate something to hold the cable sheath. https://www.trifive.com/d1/garage/56 Chevy Assembly Manual/313-7.gifLooking for a column cable adapter kit that goes from original column to powerglide trans. I see the kits that go to the TH trans but do not know if they work for PG. Thanks
Do you have worn out bushings? The stock linkage is pretty bulletproof & dependable.Ok, thanks. The original linkage is a bit sketchy and is why I wanted a cable shift replacement.
