Hey Everyone,
This weekend my hope is to replace the bushings on the front end. I've got most pieces ready to go, but have a question about how the process goes.
I have the shop manual, but when they talk about knocking the lower ball joint loose is where I get lost. So I understand you loosen the cross shaft bolts on the lower control arm, remove the nut/cotter pin on the lower ball joint, but then where do you go from there? If anyone had any visuals on what the manual is referring to I would greatly appreciate that, or any tricks you may have learned to make the process easier.
I did find one thread talking about loosening the upper control arm nut and using a jack to compress lower control arm, but I wasn't sure how that would work out.
Any help would be greatly appreciated.
