Just more info,
A ballast resistor, like ours, is simply a load coil, with the same values at either end, there is no dedicated IN and OUT end, nor polarity. If you put the power wire on an end, the other end will have the loaded volts be lower when the end user is active, such as the ignition system operating.
That said, MALLORY Uni-Lite systems like a few things, like double ballast resistance, dead stock coils, smaller spark plug gaps, good magnetic suppression, spiral core wire sets, and, they are by no means, even close to an HEI system, they make stock point levels of spark volts, NO MORE.
Coils, stock is great. (please note: there are NO drivers, dwell extenders, nor electronics in the Uni-Lite to increase dwell [coil voltage saturation], so, a "super duper, ultra high zoot, mega volt coil", when used on this system, simply AIN'T).
Wires, as stated above, a good set would be a pre-cut 7mm diameter replacement wire, the best ones being sold under the brand name Borg-Warner "Select" (O'Reilly has them, low cost, lifetime warranty, as good a wire as any "name brand performance" wire). 7mm diameter is just fine for any Uni-Lite, no matter the coil used.
Spark plug gap, NO LARGER THAN .032 MAX GAP.
Now, for the double resistor Uni-Lite systems like to 'live long and prosper' on. When we run a Uni-Lite on a distributor machine, Mallory specifies using a dry cell lantern battery to power up the Uni-Lite module, between 6.5 and 9.5 volts, NO HIGHER VOLTS. We already know the porcelain resistor on the firewall, or, the resistor wire in our vehicles rates out at 1.80 ohms, +/- 1 percent variance (this porcelain resistor can be obtained with NAPA p/n ICR13). This resistor (or stock resistor wire) would be needed left in place and operable between the power source (ignition switch), and coil + terminal. This makes for the first resistor, and drops working volts down to roughly 11.0 volts.
Second resistor would be installed between coil + terminal and RED Uni-Lite power input wire, to second resist the ignition module. The small porcelain resistor that comes with a Uni-Lite is actually a MOPAR derived one. Boots Mallory started his distributor business using over the counter Chrysler parts, like caps/rotors, coils, resistors, and the one for the Uni-Lite is still MOPAR spec. It is one used for the earliest 12 volt, single point ignition systems in Chrysler, Dodge, Plymouth, rated at 0.60 ohms. This second resistor further drops the line current down for a Uni-Lite to about 9.0/9.5 operating volts.
Yes, we hear all kinds of notable sources insist that the new Uni-Lite systems don't need a ballast resistor, but, when they constantly go blind, you will finally realize, they do. The other fallacy is that they make more spark energy than a stock point distributor. NOT TRUE, they have no electronics/drivers to increase coil saturation, and that saturation is the thing that makes the higher volts. The benefit is, Uni-Lite makes the same spark energy that a brand new set of points do, the first spark out of the new points, and don't drop volts off as it ages, not like the points do.
Almost every GM vehicle that used both 12 volts and points, use a separate wire from the 'R' terminal on the solenoid, to the + side of the coil, to add a full 12 volts to the system, AT FIRE UP/START ONLY. This full voltage drops off when the starter is disengaged as the engine starts, then, the system reverts to resisted power, fed through the ignition switch.
On very few GM vehicles that used points, usually military vehicles, trucks, the feed wire from the firewall bulkhead to the coil, doesn't go to the coil. It is run from the firewall connector, to the 'R' terminal of the starter, then, a single full copper stranded, non-resistor wire is run from the 'R' terminal, to the coil +. In this method, the IGN term feeds the firewall connector and resistor wire, the resistor wire feeds the 'R' terminal, and, on start up, full volts are used from 'R' to coil +. Then, when the starter is de-energized, the resistor wire feeds the coil +, through the solenoid 'R' terminal, for dropped current to the coil. This system setup is very, very rare.
Just a simple primer for correct care and feeding of your Mallory Uni-Lite.
