What type of system/connections are you guys running for pcv on hi perf motors? also what are opinions on running one at all as opposed to just venting the valve covers...for street cars
Hi Mikko,Green rodder...that's great!well, I like to max the amount of fresh air/fuel mixture in my induction system...as far as I know, oil mist is only good for detonation...if you can make more power out of it I'm all in
fiftyfive210,I had a major oil use problem with my 396 that I solved.
Yes, thanks for the tips! Shortly after I got the car and realized it was using oil I pulled the PCV and saw no baffle. I knew that couldn't be good. Also as you mentioned, the location was bad. The combination of short valve covers and HV oil pump probably swamped the valve. I moved it to the top of the cover to get it away from the oil and I added a baffled rubber grommet. That along with the Mopar oil separator did the trick. It still uses about 1 qt every 1300 miles, but I can live with that.Hi Mikko,
Your points are well understood, and you're right about potential detonation, and also there's probably a tiny power loss.
In the OP's post he did mention "for street cars".
I know guys who run PCV's with no breather at all on the street. The theory being that the vacuum pulls the crankcase to at least even if not to a negative pressure. I tried to explain to them that at upper R's the valve closes, but it fell on deaf ears. I got curious though and tried it myself a couple of times. I didn't notice any difference from my usual way so from then on I went back to my valve plus breather, as it also gave me an oil fill by pulling the breather. I like the oil fill on the drivers side myself.
fiftyfive210,
I could be wrong but in your first pic it looks like the placement of the PCV hole might be right over a rocker, at speed it would spit oil right up into the valve. In your 2nd and 3rd pic with your 'test' contraption it's obvious that you drilled out the blank cover hole and plugged the first one. That alone might have helped. There's also the possibility that your valve might have stuck open. I had that prob once myself. It took a while for me to find out that mine was only partially closing.
Also, on an unrelated subject (sorry), your intake looks like a Holley Strip Dominator. I really like them things, but I found through experimentation that my 396 ran FAR better on the street with a good dual plane, even an aluminum GM intake worked way better. I was bummed, but couldn't argue with success. I did find however that the Holley did work good on 468 plus motors. If you get bored sometime try a dual plane on your 396 just for kicks.
Dan
I agree 396 should have a performer or a weiand strealth could make 30 to 40 hp more on a 396.Hi Mikko,
fiftyfive210,
Dan
That's exactly how I have it and it works well for me.I will use a pcv on one cover since I do want some sort of active way to draw contamination thru and out of the crankcase....but I will not attach the opposing breather cover to the air cleaner, and instead just use an open breather there since at WOT when I'm looking for the most power I will not allow the contamination to enter the air cleaner via that route...
I've always wondered why it doesn't act like a big vacuum leak since its connected to what is essentially an open air source.Again if I'm understanding this correctly, this PCV valve will require less vacuum to stay closed or nearly closed at idle and cruise, thus not giving you essentially a large vacuum leak at idle.
The reason it's not a big leak is pretty straightforward. The hole that the air passes through in the pcv valve is pretty small. That's why it's "controlled".I've always wondered why it doesn't act like a big vacuum leak since its connected to what is essentially an open air source.
I understand your anality about the seal Mikko. But you gotta admit that there's no way that rings can seal ALL the pressure, no matter how precise. Then there's time and wear to take into account. Running a PCV valve is sorta like putting a bandage on to make an effort to control some of the vapors. There's hardly nothing that makes a motor appear worse than having the "blue wisp" at a car show.Dan, the air cleaner I have works like velocity stack...it is circle track style and my engine made more power with it than without.
You wont find me pushing that oil smoke up in the sky...top notch ring seal is the key...I went great lenghts to get that right. Half filled cemented block, "stress" honed cylinders etc.![]()
Your point is funny.you talk about air cleaners, how many guys have the usual 14X3 on? i think it`s K&N`s site, but there`s a math problem for the correct size air cleaner. usually, the 14X3`s are to small. my little 355, with the standard 14X3, was choking, according to this. so imagine all those high horse engines, from the factory with 14X3`s, choking!
