Engine: 350 GM creat (290 hp).
Distributor: Mallory Unilight vac advance
I put a vacuum gauge to full manifold vacuum just to see what was going on and the vac gauge won't hold steady. It's not much movement but not steady. Gauge reads 15 hg showing late ing. timing. So I tried adjusting the timing. every time I move the distributor one way or the other the engine runs rough no matter how much I move the distributor. I tried compensating with idle mixture screws made no difference. Any thoughts on what could be going on? I should be able to turn the distributor and the engine not run rough. Thanks
Todd
Todd
